HELP! My Driveshaft is Stuck
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jc71355, Apr 20, 2003.
  1. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Well I swapped rear ends and put the old yoke on the new axle. Had a bad vibration so I loosened everything up and made sure I had the axle square on the springs two seperate times. Well by the end I had it smoothed out alot but it was still vibrating. Before I got home it threw both caps off the U-Joint at the axle but the straps are still there and tight. Well I went to pull the shaft and I can't get it out of the transfer case. Anyone know what could have it hung up or what would cause the caps to come off the U-Joint? The straps were still torqued down. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    TIA,
    James
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    probably caps slightly smaller idameter than what is correct, i have seen this happen before, there are a couple different size caps for half ton, kind alike 12 botl vs. 10 bolt
    i assume this is on a 1/2 ton
    dunno on the trans case output end of the shaft, hmm, wierd..
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Did it have C-clips? Mabye you forgot them?
  4. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Steve,
    Thanks I think you hit the nail on the head. Now that I think about it I didn't check after I got them pressed on. /forums/images/graemlins/eek.gif
    Randy,
    I dunno what's got that thing stuck. I talked to my uncle and he said he's had them do it to him before and to take a small jack and slowly work it out /forums/images/graemlins/crazy.gif. I'll give it a shot /forums/images/graemlins/tongue.gif
    *edit* sorry got the names mixed up the first time /forums/images/graemlins/crazy.gif
  5. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Would it be safe to say this would be the cause of my vibration?
    Thanks again,
    James
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    on my truck the slip yoke was a PITA to get out(had to hammer it out and hammer it back in) come to find out the tail shaft was cracked and it was wedged against the yoke making it a PITA
