Help!, my engine caught on fire!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BayouBlazer88, Nov 6, 2002.
  1. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    Ok, I just got finished putting my engine back together after replacing the headgaskets and when I went to start it up, a column of flame shot out of the throttle body. Also, where is the #1 spark plug terminal on the distributor in relation to the wire connections? Could it be that the timing is off? or that there is a short somewhere in the throttle body itself that is causing the fuel to ignite before it enters the cylinders? Could it be that we have the wrong throttle body base gasket? Let me know. thanks.
    Matt
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Are you sure you got the spark plug wires all in the correct spot.
    That happened to me once, you could easily (with 8 wires) to mix them up.
  3. RedneckK5
    RedneckK5 Registered Member
    Aug 15, 2002
    42
    texas
    #1 should be on the left frt of the dist. closest to the #1 cylinder. firing order is 18436572. make sure you are up on the compression stoke of #1.
  4. RedneckK5
    Aug 15, 2002
    42
    texas
    maybe this will help you see better.
    ----65
    ---3--7
    ---4--2
    ----81
    ---carb
