Help my figure this out
Discussion in '1982-Present GM Diesel' started by RLBstein, Jul 15, 2003.
  1. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    I have something on the radiator that looks like a temp sensor but I have no wire hooked up to it and my temp sensor works so it's not that. If your looking at the front of your truck, look at the left side of your radiator (passenger side) and there is something screwed into it that has a pin on it (its pointing to the engine) that looks like a wire slides onto it. Anyone know what it is for. I'll will try to get a pic of it soon.
  2. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I know the sensor you're talking about, I have a wire hoooked up to it but I'm not really sure what it's for...
    Rene
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    It may be a coolent lever sensor for retard light. Mine is hooked up by a single wire.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Yup, it's the sensor that's connected to the "Low Coolant Level" idiot light in the cluster. I never quite understood why GM felt the need to install that setup on a 6.2.
    FWIW, my "low coolant" light flashes on from time to time. After getting out of the truck and checking for blown coolant hoses about half a dozen times in the first month of owning the truck I learned to ignore it.
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Check the wire comming from the sensor. They have a habit of getting mashed by the (passenger or front) battery /forums/images/graemlins/blush.gif
  6. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    I think it´s very helpfull.I drove around with my Jimmy for a couple of months with a broken radiator. If I opened the cap to check the level it leaked much more so I drove until that light came on and then filled it up.
