Help my speedo quit working and check engine light comes ON
Discussion in 'The Garage' started by George_Pimpdaddy, Mar 28, 2005.
  1. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    :( hey i was driving home today when i noticed that my speedo in my 89 blazer quit then shortly after the check engine light came on i pulled over and shut the truck off and checked everything under the hood and checked most fuses and electrial like other gages and interior lights. i drove the rest of the way home and stopped at my local NAPA shop and picked up a new rear seal for my transfer case cause my old one was leaking a bit i noticed. Could that have something to do with my speedo problem and if theres no speedo input to the computer would that trigger the check engine light??? im planning on putting in that new rear seal in the 241 tonight and change the engine oil as well as check the rest of the truck out also does anyone know how much oil the np 241 takes i know that it takes ATF. thanks for any help :dunno:
    :k5: 355/700r4/np241
    10bolts that need to go with a posi in the rear
  2. dyeager535
    26,979
    Probably what the issue was.
    VSS is speedo driven, if speedo quits working, VSS signal to ECM was likely lost.
    Pull the code(s) with a paperclip...if a VSS code, you know almost certainly why.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I think the speedo on an '89 is mechanically driven, so check the speedo cable. If it is intact and properly connected, the gear at the t-case could be stripped.
    On that style of setup the VSS signal comes from the speedo, so when the speedo stops - the VSS signal goes away.
  4. big_black_blazer
    big_black_blazer 1/2 ton status
    Dec 19, 2004
    114
    Western Kentucky
    np 241 holds around 2 qts
    no speedo signal = no vss signal = orange light on dash... mine's been that way since october
    NAPA doesn't even have the cable in their paper catalogue, niether does Advance or O'Reiley's or Autozone.
    GM has it for like $35 or so
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Crawl under your truck and make sure the speed o cable is still connected to the xfer case. It may have just unscrewed its self. Fluid may also leak out of the place where it connects to the xfer case if the cable is disconnected so maby that will fix your leak too.
  6. George_Pimpdaddy
    Oct 17, 2002
    1,306
    i can only hope its a easy fix like that and thanks for all the info guys im planning on taking a look tonight ive been to bust from wrok to look yet. and i talk to a frined of mine who says that its either the speedo gear (how hard is that to replace???) or the cable. gonna look into it tonight peace :cool1:
