Help ... my tailgate is stuck
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BAD LUCK 79', Apr 19, 2003.
  1. BAD LUCK 79'
    BAD LUCK 79' 1/2 ton status
    Oct 8, 2001
    130
    Panama city Florida
    Hey all.. alright .. first off i feel stupid as [censored]..... i put a new seal on the tailgate and then closed it... only problem is now it's kinda stuck... it won't release by pulling the handle and with myself and my neighbor pushing on it to try and get it to release... anyone have any ideas how to get the latches to release???
    /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Jump in the truck and crawl back there and take the access cover off the gate. Then pull the two rods towards the middle and somethin should happen. Thats the only way Id know how to do it.
  3. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Thats right... the handle has 2 perpendicular metal "plates" on it. one on each side pointing forward and back. If those get bent the handle will not work well at all. Atleast thats what happened with me.
    1) Be sure to Roll your window down.
    2) go to the back and unscrew all the screws and take the cover off. Now from the out side there will be 2 rods make an "X." Pull both of them towards trhe middle and that should unleash the latches. If that doesnt work then guess you gotta bust out the sledge and saw. lol jk /forums/images/graemlins/eek.gif
  4. Grim-Reaper
    7,385
    Atlanta
    There is a lock mechanisim set up that if the window isn't all the way open it locks out the latches and will not allwo the gate to be opened to protect the window. Take the pannel off inside. All the way at the bottom will be a L shapped bracket in a slide that he window has to hit when all the way open. The spring broke on our 79 one time and let that thing goof up. Check that.
  5. BAD LUCK 79'
    Oct 8, 2001
    130
    Panama city Florida
    Thanks ya'll.... i'll have to try it this week if i get off before 12 hours at work... i figured that would work... i just hope the latches will release... especially since i just rebuilt that tailgate.......
