Help, need 14 bot FF set up for 1 ton
Discussion in 'Pacific Region' started by Eric M., Oct 27, 2002.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Mine is almost split in two. No, no wild wheelin' story. Truck was hit from behind and car went under hitting the dif. It is a 1 ton truck, so only a 14 bolt off a 1 ton will work (single or dual wheels). Gotta be 4.10s also. Yeah, it's a long shot ... I've posted in the wanted forumn but thought I'd ask here since most are local to me.
    Thanks,
    Eric M.
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Pick your Part in Milpitas had about 6 trucks all with 14BFF in them, i am sure some of them have 4.10's
    might be worth a look
  3. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Thanks. I might go check that out.
    Eric M.
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    depending on when you want to go, i could be availble to come help. lemme know
  5. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    If no luck.
    Shoot up to Newark on your way home and look at Pick'n'Pull
    They had about 10 3/4 14ff. I picked mine up for $160.00
    GOOD LUCK! /forums/images/graemlins/truck.gif
