Help , need a injector and ...
Discussion in '1982-Present GM Diesel' started by K10ANDYKHAMNIC, Jun 12, 2003.
  1. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    one of the fuel return line nipples busted off one of my injectors anyone have a spare or a fwe spares for me ?
    Do i need to get new head bolts if i take off the heads and intake the find out the condition and the knocking noise in my motor ? thanks -andy /forums/images/graemlins/ears.gif
  2. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Hey Andy
    well that sucks about the knock ya just got this motor right ???
    and the nipples are only $ 2.14 each at the chevy dealer
    i had 2 recently order some 4 mine also only took 2 days 2 get in
    now on 2 ur knock probably its the bottom end knocking not the top un less ya can hear 4 sure that its in the top and yea i believe it depends on what year your motor is weather or not ya retro fit it with the new bolts
    there are many outher here on ck5 better Qualified 2 answer that 1 for ya
    good luck
    2 ya
    Randy
  3. stu
    stu Registered Member
    May 2, 2003
    59
    Bucks County, PA
    when does the knock occurr. all the time, when accelerating, etc.?
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You don't have to change the head bolts on a 6.2
    The 5.7 had the Torque to yeild bolts, but the 6.2 has reusable bolts.
    At least that is what I read.
    If I am wrong I am sure someone will chime in /forums/images/graemlins/smile.gif
  5. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    The 6.2 bolts are TTY as well, you should be able to get a set of fel-pro bolts for around 18 bucks a set at autozone.
  6. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    when i left off the gas it really starts up , it kinda goes away if i floor it .it is really intermitant . it doesnt do it all the time . i found a broken of glow plug but and i tried o get the piece out but wasnt able to . i bought the truck like it is . /forums/images/graemlins/thinking.gif /forums/images/graemlins/ears.gif
  7. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    how do u replace the nipple ? i know the knock is in the top end for sure . i bought the truck with the noise and hoped it would make it home hehe .
  8. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I've seen (heard) a few 6.2s that were "knockers". My own Jimmy started doing the same thing shortly after I bought it. I feared the worse, even had the oil checked for bearing metals - nothing found. Kennedy Diesel told me alot of the noise can be attributed to sticky lifters. So I ran 40/60 blend of 15W40 and ATF in the motor, let her run at idle and low speed for almost an hour. Changed the oil & filter (back to 15W40), presto knocking gone. 'Haven't heard it since. /forums/images/graemlins/thumb.gif
    Hey give it a try, can't hurt - much /forums/images/graemlins/grin.gif
  9. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    real easy pull the old nipple off just dry rag wipe it clean stick the new 1 on no silicon or outher stuff needed
  10. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    UMMM ok , but it broke off . i mean im a machinst and stuff so i know i can get it out..... /forums/images/graemlins/thinking.gif i dono ill take it back out tomorrow and check it out .
