help need basics on adjusting fuel/air? on carb
Discussion in 'The Garage' started by LKJR, May 30, 2003.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Ok guys I need some help bad, went and drove the blaze while ago to pick up a trailer after doing the HEI swap, well it idles good and revs good in the driveway but on the freeway it's dumping black smoke like all get out. bad bad
    too much fuel is my guess, cause it's running like crap as well when driving.
    I've got a carter AFB on it so it should be much the same as an edelbrock.
    I know there's two screws on the front....
    lead the blind here how do I get her back to running good...
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    The two Idle air srew's are just that Idle air. Sound's to me like it's running way fat on the primary circuit, a little rejetting, and playing with needle's should fix you up.
    Carter used to make a strip kit, I think they still do, it contain's, jet's, and needle's, to get it jetted properly. /forums/images/graemlins/grin.gif
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    If it idles well do not touch those 2 screws. All they are is idle mixture screws, they have nothing to do with power under throttle. When you did the HEI swap did you regap your plugs? With HEI they can be gapped .045. What do your plugs look like? Could the black smoke be from oil?
