Help, need bolt removing secrets.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Derf00, Apr 2, 2001.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I am doing some interior repairs and need to remove the rear lap belts on my '90 Jimmy. The bolts have a torx head, and will not budge. The front belts were installed with a regular bolt and easy to remove. Anybody have any good advice?
    Derf00
    http://www.derf00.coloradok5.com
  2. timebomb1602
    timebomb1602 1/2 ton status
    Mar 30, 2001
    138
    hudsonville, MI
    try soaking them in penitrating oil overnight then reef on them with a breaker bar
    1991 GMC Jimmy, 350 tbi, stock for now, but not for long!!!
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Just ran into that on an '88. They must have used an impact wrench set on "stun" to install those bolts at the factory! Had to just keep torqueing on them until they came loose. [​IMG]
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Here's a great tool to use for things that just don't want to come apart: <A target="_blank" HREF=http://www.sears.com/sr/framework/home.jsp?BV_SessionID=@@@@0893724934.0986252530@@@@&BV_EngineID=kalkhlfllmdbgfbmgclchm.0&targetPage=/product/summary/productsummary.jsp&vertical=TOOL&pid=00947641000>Impact Driver</A>
    You smack it with a hammer and it forces the bit down as it applies a quick, sharp, twisting impact to loosen the stuck bolt. Sears stores usually have them in stock.
  5. Glenn
    Glenn Registered Member
    87
    North Kingstown, RI/USA
    Heat them up with a torch.
  6. dyeager535
    26,975
    Almost 100% sure that they used loc tite on those things, and that rust doesn't help the exposed studs. I wouldn't use heat only because you will ruin the belts. I broke off a T-47 (that IS the correct size BTW, nott-45, not t-50) in an '86 in the yard trying to get the belts I needed. Impact is probably the only way to go.
    Dorian
  7. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Try heating up the bolt a bit with a torch (not red hot though) and squirting some PB Blaster or WD40 on it while its warm. The heat will suck the lube into the threads kinda like when you solder. Then drive'ah!!
    Why do people keep calling it a Bronco!!!!!
  8. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I broke 2 torx's then got the 3rd torx and vice grips on it too, broke that torx too. Tried every thing pb plaster heating it up, still wouldn't budge, so i got pissed and got stupid and just burned the biatche's out with the torch!!!!! I wouldn't recommend this. I'm just going to use some grade 8 bolts for them now
    Doug Krebs
  9. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Try PB Nut Blaster. You'd be amazed at the stuff it loosens! It's a lot better than WD-40.
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  10. scavenger
    scavenger 1/2 ton status
    Mar 31, 2000
    111
    Southern Wisconsin
    Here is trick that I have used with good results. I once faced the same problem you have and was at the end of my rope trying to get them buggers out. I momentarily thought about heating them up with the torch, then decided that the fire dept was too far away to take chances. I then decided to use my welder to heat just the bolts. I connected the rod holder under the blazer on the seat belt bolt, and the ground clamp on the bolt head on the inside. I set the welder to 90 amps and flipped the switch and let it cook for about a minute until I smelled it heating up. I then sprayed the bolt head with a little water to cool it down. It still took a little effort, but it then came out using the torx bit. It still dosn't make sense to me why this worked, because I would assume that the bolt would expand from the heat making it even more difficult to remove. On a word of caution I would disconnect the negative battery terminal, and unplug the harness from the computor to lessen the possibility of frying electrical items.
  11. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    the reson that work is you hit it with cold water witch if it cooled srank the bolt making looseing up just thgouth i drop that in if you keep breacking tools take a weld a nut on to the top of the bolt then you can use a normal sae or metric socket or wrench on it
    Bandit
    (Your right i dont understand the jeepthing)
