HELP!!! Need flywheel cover info ASAP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DieselBurb, Feb 27, 2003.
  1. DieselBurb
    DieselBurb 1/2 ton status
    Oct 8, 2002
    201
    Mt. Vernon, Missouri
    Long story short, I just got my truck back from the tranny shop after it sitting there for a month and a half. I crawled under it to look at the work and found that they had put a plastic flywheel cover on instead of the heavy cast aluminum one with support braces on it that it had when I took it in. The truck is an 85 K20 /forums/images/graemlins/burb.gif, 6.2, np208. I need to know if they are trying to stick it to me.
    Diesel /forums/images/graemlins/burb.gif
  2. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    You want to get the cast aluminum one back in as soon as possible!
    The tranny will torque more without that on.
    When I bought my Blazer, it was not there.
    I put a mini starter on and when I would put my foot in it, the flywheel would clip the starter teeth. I put the cast cover and braces on, no more problem.
  3. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I had that happen to me... /forums/images/graemlins/frown.gif
    But I was running a 203...
    With all the weight the trans had to support...
    eventually I broke the belhousing on the trans...
    from JUMPING my truck...
    If your wheeling your truck...the same thing could happen.
  4. dyeager535
    26,979
    It was there when you took it to them, it should be there when you get it back, regardless of whether it is "functional" or not.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    most definetally should be there, they replaced what I am guessing is a fairly expensive part with a piece of cheap plastic without notifying you, thats stealing in my book, probably would be in the eyes of the better business bureau or the police as well.
  6. DieselBurb
    Oct 8, 2002
    201
    A little history
    The only exception is that they didn't build a case for a diesel, they built one for a gasser which means the case is thinner and the aluminum cover doesn't bolt up. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    I am going to duke it out this afternoon
