help! need some advice on a hard to find part...
Discussion in 'The Garage' started by offroadnut, Mar 13, 2005.
  1. offroadnut
    offroadnut 1/2 ton status
    Jun 5, 2003
    116
    Indianapolis, Indiana
    I dropped my fuel tank last night to replace my fuel sending unit. it was rusted and leaking. I also have a bad mainline section of hose. The truck has a 10 or 12 inch section of Braded Gas line with a compression fitting on the end that goes to the hard line gas line. that compression fitting is now loose and leaking as well. none of the normal part stores around here have it... any idea's for a fix...
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    dealer then
    or junk yard
    good luck
  3. dyeager535
    26,977
    Stock steel braided fuel line is fairly universal between similar year GM cars. Slightly different lengths from what I've seen, but not that much.
    You say the fitting is loose, as in the crimp to the braided section, or where it is mated to the sender? Depending on that, is the o-ring shot? Usually they should be replaced when the line is pulled, they are what seals the line to the fitting.
    FWIW, I can *probably* provide the part numbers if your local GM dealer can't get them for you. That is of course, if you want brand new. I'd get the part numbers from the dealer in your case, then go plug them into gmpartsdirect.com. They always beat my dealers prices by a large margin, even with the shipping costs.
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    those are still avalible from dealer. i put some on at work a few months ago for customer.
