Help....need tunerpro compatable .ecu files
Discussion in 'The Garage' started by beastofablaze, Apr 6, 2005.
  1. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    anybody happen to have a 1227747 tunerpro compatable .ecu file that i could use?
  2. dyeager535
    26,980
  3. beastofablaze
    Apr 4, 2005
    441
    CA
    how do I get it to work in tunerpro? I click on the link and it shows me a bunch of words and numbers... do i copy the link to tunerpro?
  4. dyeager535
    26,980
    Looks like you hit the link before I changed it. I saw the same thing you did. :)
    Go to the link now, go to downloads, ECU files I think it is, then click on the link for the 1227747. SAve it to wherever you want. Open up tunerpro, click on "ECU", "Select ECU", then navigate to where you saved the .ecu file from marks site.
    The tunerpro folder has another folder inside it for ecu's, might make it cleaner to keep your definitions in those folders. Rename your new .bin too.
