HELP NEEDED About to buy this need to know if the bolt pattern is the same
Discussion in 'The Garage' started by speed_deed, May 15, 2002.
  1. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    As many of you know i need a carb for my '85. A friend of my dads runs the goodwill's car program here and just said he has a EDELBROCK CARB #1406 That he will give us a deal on!! I need to know if the bolt pattern is the same to bolt onto my stock q-jet intake manifold. ?I am sure the carb is square flang but they have adpaters for that. WILL THIS CARB BOLT IN TO PLACE ON MY INTAKE MANIFOLD????
    If yes I am going to get it, If no I will be needing a good deal on a manifold it will fit, or I cant get it. HELP
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Someone correct me if I am wrong but I think it should fit on a 85 fine on that manifold (without air injection too I think cuz it's not legal on things that have to be smogged ).... it's an electric choke and it is like you thought square flange. Go to the http://www.edelbrock.com site and try the find part by type of vehicle. I looked at this just a little bit when I was having carb issues so I don't recall much more then this...
  3. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Only Spreadbore carbs will fit on a stock intake without some kind of adapter. So the Edel Squarebore isn't going on there with out an adapter plate, if you had a Edel intake it would go on because the edelbrock intake has the squarebore bolt holes as well as the spreadbore holes.
  4. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
  5. speed_deed
    Jun 15, 2001
    947
    Valley Center KS
    Thanks people. I asked the edelbrock parts finder which carbs would work and It came up with this one. I will have to buy the edelbrock adapter part # 2696. I found it for $33 not too bad depending on the deal I get on the carb. This reminds me... I have to go call that guy! /forums/images/icons/laugh.gif I have been cleaning out the garage all day and totally forgot about it!!!!
