help needed!!carrier swap
Discussion in 'The Garage' started by chevy wrangler, Apr 30, 2007.
  1. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    would it be to swap ring carriers on a dana 44 axle??
    i just found out i sheard the gears off of the spider gears in my d44:(
    i dont want to swap axles but if its alot easyer then swaping carriers out then i guess i'll have too:confused:
    anybody help!!!plez
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    You can change just the spider gears, which is easier than swapping carriers and ensures you won't change the ring and pinion setup. Make sure you get all of the metal chunks out of there.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Why not just swap in new spider gears?
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Ditto. Just make sure you get all of the old metal out (so as not to take out the carrier bearings or whatnot).....and just swap the spiders. You should be able to find D44 spiders for around $20...and they are very easy to swap in. As others said....its also an easy way to make sure that the ring and pinion are already set.
    -Harrison
  5. Speedo
    Speedo 1/2 ton status Premium Member
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    Swapping in a new carrier would require shimming the bearings to establish both carrier bearing preload and backlash between the ring and pinion. Unless the carrier is damaged it would be much easier to just replace the spider gears.
    Gus
  6. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    so how do u replace them?? thanks for all your help guys
  7. 1977k5
    May 26, 2003
    9,992
    130
    Pop off the cover and let the fluid drain. Disassemble the hubs and pull the shafts. There is a small (likely allen head) bolt running horzontally through the carrier. Remove that, then remove the center pin (the big shiny one running through the center of the carrier). Then remove and replace the spider gears.
  8. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    cool now where do i get them from??
  9. 1990 tbi jimmy
    1990 tbi jimmy Registered Member
    Dec 11, 2005
    11
    florida
    It was cheaper to buy a posi unit than the spider gears when I toasted mine. I had a friend set it up and have a posi!!!
    JW
  10. 87BrnRsd
    Apr 21, 2003
    2,457
    Look in the for sale section on this site. Or go to a local junkyard. D44's are extremely common and you shouldnt have any trouble finding some spiders for it. I wouldnt pay more than about $30 for a good used set.
    -Harrison
  11. 87BrnRsd
    Apr 21, 2003
    2,457
    You either got a hell of a deal on a posi or were being asked to pay an ungodly amount for some simple spider gears. There is no way that a posi should ever cost less than some spiders...unless its free. Heck a lot of people will just give them away. Anyone who installs a locker will have spare spiders just lying around.
    -Harrison
  12. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    well which would work?? from what axle years?? anybody have some layin around they wana get rid of??
  13. 1977k5
    May 26, 2003
    9,992
    130
    There are two spline counts for dana 44's: 19 spline and 30 spline.
    Look here for some info:
    http://77cj.littlekeylime.com/web_rs44.html
    But really, only the really old dana 44's are 19 spline.
  14. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    its gotta be a 30 spline because i got new axleshafts once
  15. 87BrnRsd
    Apr 21, 2003
    2,457
    You have to pull the shafts out anyways to take the spiders out, why dont you just count the splines then? Its probably a 30 spline. Once you pull the shafts you will know for sure and just buy the same thing.
    -Harrison
  16. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    yeah there 30 spline i counted the ones off of my totalled axle shaft
  17. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    okay so i got a d44 housing with 3.73 gears that match the front ones, i poped the dif cover off and it is all good inside, so what will i need to do to take the spiders out?? i pulled the pin out with a pin punch and when i pushed the rod out it hit the ring gear!
    so i took out the carrier and i am thinking of just swapping em out.
    whats the whole backlash thing??
    i dunno whats best,
    anybody help!!
  18. Speedo
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    You can't just swap carriers without changing ring gears. Since you will have to pull the ring gear anyway just knock out the pin and pull the spiders and thrust washers. If you keep the carrier that is in your axle the shims are already set up for your ring and pinion you just need to put the spiders into your old carrier.
    Gus
  19. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    so i pull the carier out from my axle?? wont that mess with the backlash and stuff?
  20. Speedo
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    Backlash is set by shims under the carrier bearings. Keep the bearing cups with the bearings that they were used with.
    Gus
