HELP needed from 'Burban owners
Discussion in 'The Garage' started by zakk, Feb 16, 2003.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    HELP needed from \'Burban owners
    I am lifting a friends '84 'burban (1/2 ton) and I an wondering about the driveshafts.
    Did you have to lengthen driveshafts with a 6" lift? i know each truck is different, i am just seeing how often it is needed in this case.
    TIA!! /forums/images/graemlins/thumb.gif
  2. dubl_t
    dubl_t 1/2 ton status
    Jun 8, 2002
    141
    Oregon
    Re: HELP needed from \'Burban owners
    I don't have the 6", just 4", but I'd bet the dshafts need lengthened. I had a truck lifted 6" and if I hit a bump hard enough the rear shaft would slip apart.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I've got the Rough Country 4" (which is closer to 5") and I didn't do anything with my driveshafts. Both have plenty of length - so I THINK you'll be alright. /forums/images/graemlins/thumb.gif
  4. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    i agree with heavy4x4, i lifted mine 6" and didn't have to lenghten my shafts. however i did after i tossed in mine 1 ton gear /forums/images/graemlins/grin.gif... lift it for now and see how things work out, you'll probably be ok unless you get real twisted up /forums/images/graemlins/thumb.gif...
  5. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    When we lifted Jason's burb (3/4 ton 14B) 6 inches nothing had to be done with the rear shaft, but he ended up putting a spacer for the front shaft.
  6. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i'm at 5" on the front and i'm running a 1" spacer to help it out, i'm only at 4" rear and that's fine. with a shaft that long you might not have problems.
  7. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    What do the spacers look like and where can I get one?
  8. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Hey Zakk
    i say they should be lengthened
    rember the 60 % of length for compression 40% for decompression A.K.A. the 60/40 rule
    here is a cool link i found
    http://www.4x4wire.com/tech/pinionangle/
    /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  9. heavy4x4
    Aug 28, 2002
    3,270
    THEY LOOK LIKE THIS
    As far as where to buy one, I think superlift or something like that sells them for about $50, but I could be wrong. Ask Muddysub where he got his - I think he had someone here make it for him though.
  10. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
  11. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    4wpw pn#04310 $65 shipped made by superlift. I have 7'' lift with stock shafts and the spacer gave me more than enough length in the front shaft. The issue with lifting and the front shaft was not so much the length, but the angle and the c/v hitting the crossmember /forums/images/graemlins/frown.gif. A little grinding on the c/v stops and adding the spacer (to move the c/v away from the crossmember) solved my problems /forums/images/graemlins/thumb.gif. I couldn't recommend anything for the rear shaft other than lift it and find out /forums/images/graemlins/tongue.gif I didn't have any problems on my blazer with 5 1/2'' lift and stock rear shaft even after I moved my rear axle back 1 1/2'' /forums/images/graemlins/cool.gif, BTW I did lower my T-case 1''
