help needed locating a cast iron SM465 bell housing
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by beater74, Jul 24, 2003.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i'm trying to find a Cast iron sm465 bell housing, i understand that they came in trucks from 68-72. if anyone here has one or knows where to get one would ya let me know.
  2. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
  3. beater74
    May 29, 2001
    1,749
    atlanta
    HMM, i really only need the BH but maybe he'll part with it thanks
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i may have one at my sisters place. my sister dump a lot of stuff, though. if it's there it's yours. just pay shipping.
    ARQ.
  5. beater74
    May 29, 2001
    1,749
    atlanta
    please let me know ASAP.
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    You can also use one off a 2wd truck that has a 465.
  7. beater74
    May 29, 2001
    1,749
    atlanta
    yes but it has to be a cast iron one
  8. JohnSPledg
    JohnSPledg 1/2 ton status
    Feb 22, 2001
    141
    Baton Rouge, La
    I have the original bellhousing from my 72. I picked up a hydraulic housing for mine. Someone give me an idea of what its worth, and its up for grabs.
  9. beater74
    May 29, 2001
    1,749
    atlanta
    if it's cast iron i'll give ya $40+shipping
  10. beenlookin
    beenlookin Registered Member
    Mar 7, 2002
    16
    Omaha, Nebraska
    I have one that I could probably just give you, I'm in Omaha Nebraska so shipping might hurt a bit. Let me know if your interested, send me a PM.
    Scott
  11. beater74
    May 29, 2001
    1,749
    atlanta
    you've got mail
  12. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    couldn't find the bell. i guess it's in a better resting place /forums/images/graemlins/confused.gif
    ARQ.
  13. beater74
    May 29, 2001
    1,749
    atlanta
    thanks for lookin /forums/images/graemlins/smile.gif
  14. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    regarding the starter on the early trucks. Did it mount on the bellhousing or on the engine block. I've seen both types. any clues???
    the one i had did have the mount for the starter on the bellhousing, it was cracked so i threw it away a while ago.
    ARQ.
  15. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I just thought of another complication for you... What side is the starter on for the Caddy 500? I think the Pontiac 455 is on the drivers side rather than pass side like the SBC but not sure about a Caddy motor.
  16. BluThndr71JMMY
    BluThndr71JMMY 1/2 ton status
    May 12, 2000
    152
    Tucson, AZ
    Be sure to check the diameter of the big round hole that the spline goes thru. There are 2 different sizes. The one that was on my '71 Jimmy had an opening of about 5.5" but the one off my '68 C/10 pickup had a diameter of only 4.5." [Sizes are approx guesses.] Not sure if this is a 4x4 vs 4x2 thing, a later model thing, a V8 vs L6 thing or even a Chevy vs GMC thing. But before you buy one, make sure you have the same internal diameter since they are different.
  17. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    3 speeds and SM420s used the smaller pilot diameter. SM465s used the bigger pilot diameter. Otherwise these bell housings do look almost identical.
  18. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    My truck used to have a 3-spd in it and I swapped over to a SM465 without changing the bellhousing.
    Will
  19. BluThndr71JMMY
    May 12, 2000
    152
    Tucson, AZ
    Don't know how I got hold of a bellhousing for a saginaw. Must've been the old junkyard switcheroo. I even painted it engine orange for the '71 K/5 build-up, back in '99, only to find it was too small. A machinist offered to bore it open for me, but it was easier to degrease and paint the [bigger] one that came off the truck. It would be funny if one of these trannies was a 420, but the reverse is hard right and down.
  20. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The '72 I had the starter bolted to the bellhousing.
