Help needed on 1/2 to 3/4
Discussion in 'The Garage' started by coptezr, Jul 10, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    i have a 2wd burb that has a 14b ff wit a 454 in it would it have 410 gears? what all do i need to do to it to get it in my truck, Also what em i looking at to spend on a conversion for the front 10 bolt to 8 lug and the rear, what about front adapters and how long will the total swap take me?
    thanks
  2. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    the only way to know for sure is to pop the diff cover and check the numbers on the ringgear
    the shockmounts sits lower on 2wd-axles than on a 4wd ...
  3. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    on the front conversion, all you need are the 8 lug hub/rotor assemblies, and the caliper backing plates. the hub/rotor assemblies you can get brand new at carquest for $67 a piece, and you can find the backing plates on ebay or junkyard.
  4. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    a fwd 8 lug hub and rotor wont fit on a 2wd spindle no way, no how
  5. coptezr
    Jan 13, 2005
    342
    ummm :doah:
  6. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    i'm pretty sure we are all aware of that. read the guy's post again. he said he wants to do the 8 lug conversion on his front 10 bolt. unless you can find us a 2wd front 10 bolt, i think you're mistaken.
  7. coptezr
    Jan 13, 2005
    342
    thanks
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    should be 373 with 454 but you just never know
  9. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Jack the back of the truck up and turn the tires slowly by hand. Carefully count the driveshaft rotations. If it turns 3 and 3/4 times, its a 3.73. If it turns a little more than 4 times, its a 4.10
  10. coptezr
    Jan 13, 2005
    342
    will do thanks ihope 410's
