help needed, please
Discussion in 'Pacific Region' started by delta9blazer, Aug 14, 2002.
  1. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    my truck has had a noise in the rear for some time now. i was told that it was the r&p, and it made sense. it is a vibration/rattle that occurs mostly at nuetral throttle, and it happens much more at 70mph and above than below 60 or so.
    my ten bolt went out a few months ago, and i dropped a 12b with 4:56's and an auburn.
    the rattle was still there. i suppose the gears coulda been on their way out, but the guy i bought it from swears they came out of a running truck, and they were good. i got them through here, so i'd rather believe that it's something else.
    someone suggested that my driveshaft is too short, but i don't want to drop another $150-200 on a guess.
    it has to be hurting something on my truck, but it's been there for like two freakin years. as long as i drive it mellow, with nice, smooth throttle, it will take me to work and back just fine, and run the whole damn family to oregon, if i need.
    we crawl under and make sure everything is tight, and the rattle doesn't go away. things vibrate loose, and the rattle/noise gets louder, but then we tighten everything back up.
    i can't keep a soda in my center console, because the truck vibrates it all outta the can.
    anybody good with drivetrain issues be willing to ride in a norcal bigdawg's truck to troubleshoot?
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Oh well then i'd believe that guy! I hate those guys that swear it was running before. AAAARRRRRRRRGGGGGGGGH!
    You've got an auburn... did you put in the posi additive in the gear oil?
    It sounds like it could be a driveshaft that is out of balance, or too short... if you've ever broken a u joint and banged that driveshaft around it could be out of balance, and never the same.
    ...or it could be the pinion angle is causing the vibe. You can use the wedge shims to change pinion angle.
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Check the rubber mounts on the T-case...
  4. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I had an Auburn Gear locker in my 72 and it made a little noise right before it blew up and the company wouldn't warranty the Durn thing it was only 6 months old and less than 3500mi. I said I would never buy another and all I run now is Detroits! Although I'd be tempted to try ARB Air Locker out!
    Bill C
  5. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    ARBs HEE HEE HEE...
    DAMN LINES keep breaking... I will be solving that with some brass lines.
  6. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Just gotta learn how to route them so they don't get damaged.
    Bill C
  7. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    It would help if I didn't SIT on them when I am working in the engine compartment. /forums/images/icons/laugh.gif
    Delta-
    Sorry for taking over your post...
    I suspect it is a driveshaft or a U-joint problem. Good luck.
    I would help if you were close to me... I just went through four driveshafts (three trucks) with AAA driveshaft in Sacramento.
  8. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    What city do you live? I am always ready to give any advice or a helping hand when I can.
  9. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Delta-
    Did you check the T-Case bolts?
    For the longest time I had problems with a major vibe. Started to leak some ATF. I got under and noticed the 4 main bolts to the adaptor had worked there way loose to the point of being only "finger tight".
    Like GoKarter said check the rubber mounts to the Tranny/T-case. I replaced mine 2 or more years ago and the rubber started to become brittle in my hands. That solved my major problems. With all of the oil an road grime and age. The replacements worked well. GOOD LUCK! /forums/images/icons/confused.gif
  10. delta9blazer
    1,646
    hey, thanks for all the replies.
    i'll crawl under there today and look at the t-case bolts and mounts.
    and i keep hearing about how all i might need to do is throw some shims in there.
    throw what shims in where?
  11. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    between the springs and the spring perches on the axle...it would rotate the pinion up or down depending on what way you need to go...
