HELP NEEDED: Something shifts after complete stop (UPDATE)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smack, Mar 7, 2003.
  1. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    Obviously this is a hard one without seeing it but after a stop, something in the undercarriage noticeably shifts after I come to a complete stop and it only seems to happen after moving forward, not reversing. I jacked both front sides up and wiggled the wheels, everything seems tight. I even tried putting a jack under the front spring's rear shackle and that seemed tight.
    Anyone had this happen?? I'm thinking maybe a worn spring shackle or a bad body mount, but damn it's hard to find. Suggestions??
    tia,
    smack
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: HELP NEEDED: Something shifts after complete stop
    Sounds like the slip joint in the rear driveshaft is binding. Have someone carefully watch under the rig as you come to a stop. The rear end lifts under braking, then will suddenly settle as the weight of the rear coming back down overcomes the binding in the slip joint.
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I'm with Harry 100%. I'd even go as far as to tell you to just yank the rear shaft, clean it out REAL good, deburr the inside of the slip on the DS's yoke, clean up the output shaft, grease the slip with some lithium grease, and slap in all back together. PROBLEM SOLVED! /forums/images/graemlins/cool.gif
    -Dan
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You could also check the rear shocks. I had that and ended up with the top mounts loose.
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i'll 3rd harry's suggestion. i had the same issue and would have never believed that the slip yoke could bind that much. it was almost like someone rearended me a 5mph after i came to a complete stop.
  6. smack
    Feb 24, 2000
    277
    Colorado
    Interesting, I never even considered that a possibility. Neatly enough, only 3 months ago I had a new driveshaft made but when I installed it I did not put any lube on the slip joint 'cos I thought it was lubed by the fluid in the t-case. This is not so??
    smack
  7. smack
    Feb 24, 2000
    277
    Colorado
    So you lubed it and the problem was solved?
  8. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    yes. i pulled the rear shaft...cleaned the shaft and slip yoke and put a light layer of grease on the inside of the slip yoke. problem solved. /forums/images/graemlins/thumb.gif
  9. smack
    Feb 24, 2000
    277
    Colorado
    Thanks all, I will "lube my shaft" tonight and let you know how it goes. /forums/images/graemlins/smile.gif
    smack
  10. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Interesting...thanks for the information /forums/images/graemlins/grin.gif. My Suburban has the exact same symptom. First time it happened, I thought someone hit my truck slightly. I got out of the truck at a light, just to check. It does not happen all of the time, usually when cold.
    I think I will lube mine this weekend, like Smack, while I am replacing rear shackles.
    /forums/images/graemlins/burb.gif
  11. gumneck
    gumneck Registered Member
    Feb 6, 2003
    89
    VA
    Not sure if mine does the same thing or not but sometimes my 1991 BLZR stock all around makes a firm bump when slowing down from say 5 mph to 0. And then when starting off from 0 to 5. Also seems more likely when very cold. Could it be bad ujoints? Tks,,
    Tom
  12. rh88k5
    rh88k5 Registered Member
    Sep 11, 2002
    94
    Burlington, N.J.
    same thing happened to me, I heard GM makes a lube that resists the tranny fluid from breaking down the grease on the slip yoke!
  13. smack
    Feb 24, 2000
    277
    Colorado
    Could you be so kind as to finding out which lube it is?
  14. JohnnyFresno
    JohnnyFresno 1/2 ton status
    Mar 24, 2002
    194
    Clovis, CA
    I lube my shaft on a daily basis.
    /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
  15. rh88k5
    Sep 11, 2002
    94
    Burlington, N.J.
    I would if I knew, It cost me $85. at a 4x4 shop just to grease my shaft.I thought my ring and pinion was shot, just ask your local shop, if not contact me and I will find out for you. /forums/images/graemlins/thumb.gif
  16. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    your suposed to lube your shaft? thats weird, well when i do the lift, ill take the driveshaft out of the rear and put some grease in it, dam, didnt know that. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  17. smack
    Feb 24, 2000
    277
    Colorado
    WELP, I "lubed my shaft" this weekend, I must say it was quite enjoyable!
    Anyway, at first I didn't think it worked, but knock on wood, after a bit more driving the problem hasn't returned.
    Thanks all!!
    And might I add, you should all feel free to thoroughly lube your shafts!
    smack
  18. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    I'm quite sure that Beaver Oil is the preferred lubricant.
    /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  19. Panther212
    Panther212 Registered Member
    Jan 4, 2003
    56
    Phoenix, AZ
    THAT WOULD BE CORRECT /forums/images/graemlins/deal.gif
  20. CamaroZ85
    CamaroZ85 Registered Member
    Feb 21, 2003
    27
    Woodbridge NJ
    Could this also cause a "bang" when taking off from a light, or when coasting and then stepping on the accelerator? The guy I bought my truck from says that this happens but I havent experienced it (havent registered the truck yet) so I havent looked into it yet. Any ideas?
