Help needed!!!**Updated again**
Discussion in 'Pacific Region' started by Gold Rush, Jan 3, 2003.
  1. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    Here is an update. I got a 203 tcase and a rear driveshaft from MJF. With some new u-joints the driveshaft will work great. That should get me by until I can get my dually back up and running. Thanks Mike!!!!!
    Update again: I put the 203 tcase in today. Non of the driveshafts I got are gonna work though. I will send the driveshaft that MJF gave me over to get a new end on it and that will take care of that. I still need an output yoke for the rear of a NP 203. Anybody have one lying around??? I do have my rig driveable for now but wouldn't want to drive it very hard or go wheelin with it until I get the driveshaft fixed and get a new output yoke.
    Thanks to all who have helped get me back on the road!!
    David
    /forums/images/graemlins/usaflag.gif
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Re: Help needed!!!
    Best of Luck!!
    Sorry I cannot help!
    You can make it in frontwheel drive if ya had too.
    Back roads brother!!
    Have a good weekend /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Re: Help needed!!!
    Soooo David, I guess this means you're not coming to pick up the top this week end. /forums/images/graemlins/frown.gif
    Well I was at pick n pull yesterday and I found a bunch of 203 Tcases.
    I was in stockton and in sacramento.
    As for the drive shaft, I have one that I had just bought when my 203 went south and had to replace it with a 205 so different shaft.
    Let me know what you want to do.
    I will be working in Tahoe until 1pm tomorrow, but after that I can and would go to pick n pull and grab you one and take it to you with the driveshaft, for a small fee.
    Or you can go to stockton and pick one up, drive with front wheel drive and come here and pick the driveshaft up. /forums/images/graemlins/cool.gif
  4. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Re: Help needed!!!
    I have my stock rear driveshaft from my 208 slip yoke. Can you use any parts from that? I was planning on hitting PnP tomorrow so I'll keep an eye out for you.
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Re: Help needed!!!
    If you want to borrow mine you could. Untill you get a new one...
  6. Gold Rush
    1,498
    Re: Help needed!!!
    Give me a call if they have one over there.
    Thanks,
    David
  7. Gold Rush
    1,498
    Re: Help needed!!!
    Where in Stockton did you go??? Maybe I can go up there and get one.
    David
  8. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Re: Help needed!!!
    I have a 203 tcase. It was mated to a 350 & I have the adapter. I also have a driveshaft from a LWB truck. It had a 205 & was a 14B rear. If any of this will help, let me know.
    Mike
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Re: Help needed!!!
    Pick n pull in stockton.
    I think there is only one.
    3927 clark drive
    Stockton CA
    pick n pull locations
    There are more locations maybe one would be closer to you, check the link above.
    203 are not the hot item, so every time I go I find a couple. /forums/images/graemlins/thumb.gif
    And if you need the driveshaft, mine is for a 4" lift 203 setup.
  10. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Re: Help needed!!!
    I just re-read the post. I thought you had broken the truck, but i see it was the blazer.
    I have a stock driveshaft from a blazer that was for a 203. I broke the front ujoint & banged it a little when it fell out onto the ground. It's been out in the rain so I don't know how bad it rusted.
  11. Gold Rush
    1,498
    Re: Help needed!!!
    I have the Marv Springer set-up so I need a stock rear driveshaft. Thanks for the address. Sorry but due to a wrong exhaust manifold and the dealer needs to special order it, I don't have the dually ready. I'll try for next weekend.
    Later,
    David
  12. Gold Rush
    1,498
    Re: Help needed!!!
    How badly did it get banged up???? How much for it and the 203 tcase??? Are you gonna be around tomorrow??
    David
  13. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Re: Help needed!!!
    Hey David, I've got a 203 t-case you can have...2 of them actually....IF you want to drive up here and get it. I can probably get ya a driveline too. My buddy usually gets like $65 for 'em...He should have what ya need. It's a long drive though..... /forums/images/graemlins/ears.gif
  14. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Re: Help needed!!!
    I know it put a few gouges in it when it hit the ground but i don't know if it was bad nough to make it become unbalanced.
    I should be around tomorrow. As far as price: You're a big dawg, so you can have it if you need it to get you running again.
  15. Gold Rush
    1,498
    Re: Help needed!!!
    Thanks for the offer Joe. I will try and get something locally or at least not 4 hours away. That's too far to drive on front wheel drive with a locker.
    David
  16. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Re: Help needed!!!
    I have a stock rear dive shaft from my Jimmy TH350-NP203
    If you need it it's all yours no cost, just gotta come and get it. Also have the rear output yoke from the NP203.Hope this helps?
    Bill
  17. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Re: Help needed!!!
    Nothing at PnP. The only 4x4 I saw had a 350/205 combo and the driveshaft was shot.
  18. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Re: Help needed!!!
    David, where do you live again? I have to drive to Fairfield tomorrow afternoon to pick up my snowboard from my friend. Bill lives not too far from me.... I could get the drive shaft and meet you someplace along I-80... that is you live in the Bay Area right? Works perfect too I need to drop off a welding video to Bill anyhow... lemme know!
  19. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Re: Help needed!!!
    He lives in Livermore..
  20. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Re: Help needed!!!
    Shoot I looked it up and Fairfield is not really a good place to meet it's way the wrong way for David... doh... well if something else could be worked out and I can help, I will....
