Help: New door wont line up
Discussion in 'The Garage' started by dduckblazer, Nov 28, 2002.
  1. dduckblazer
    dduckblazer Registered Member
    Apr 17, 2002
    64
    Los Angeles
    I just got a repalecment door. I left the hing bolted to the body and unbolted it at the door. When I bolted on the new door it dosent want to line up. I tried moving it up. Still needs to go forward and up about 1/4 inch.
    Any tips or tricks to make it line up right?????
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    You'll have to move the body side of the hinges. Mark them with a scribe all around the hinge and then loosen them off and adjust the location. Snug up the bolts and try it again.
    There is one bolt that is a PITA because it comes from inside out unlike all the others. Up under the dash is a rubber plug and an access hole. A deep socket will work. Being double jointed would also be an asset./forums/images/graemlins/wink.gif
    I set my doors so there was an equal space all around the door. I did this with the striker bolt removed...then I set the striker bolt last.
    Be prepared to have to spend a few hours getting it just right. The door should close and latch with minimal effort.
    Rene
  3. FunintheMud-K5
    FunintheMud-K5 Registered Member
    May 4, 2002
    38
    Waterville, Kansas
    Well if its a replacement door and not a GM Door..Then all i have to say is good luck to you..I used to work at a Body Shop and always dreaded replacing doors or fenders or anything aftermarket..They took forever to line up correctly and some didnt...Gotta love GM Parts..I have 2 doors and 2 fenders that are aftermarket and just dreading putting them on...
    Bill /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
    http://groups.yahoo.com/group/trailkrawlers4x4/
  4. dduckblazer
    Apr 17, 2002
    64
    Los Angeles
    Its Gm , Came off a blazer
  5. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    You may want to replace the hinge pins. When I put my NEW GM door's on, they lined up fine, but there was a bit of play in the hinge-- the local NAPA store had them for like 13 bucks each...
    Brandy
