HELP!!! New lift, now need brake lines...
Discussion in 'The Garage' started by 86haubs, Jun 10, 2006.
  1. 86haubs
    86haubs 1/2 ton status
    Nov 14, 2005
    196
    Lemoore, CA
    Okay so I finished putting the lift on My burb tonight, but now my brake lines are too short. I can barely turn the wheel. Getting the lift and tire was like pulling teeth from the wife, so don't really have the money for extended lines, HELP!!
    I was thinking about getting '99 3/4t burb lines, the are 25 inches, my stock is 20". Will this work, has anyone done this, or have any suggestions.
    The Superlift kit came with the brake brackets, but I do not think they will help enough!
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If your front axle is a 10 bolt then yes those lines will work. I run pretty much the same lines on my K5 and they should only be about $13 a piece. What about your rear brakeline how tight is it?
    Ira
  3. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    It is tight, but not that bad., it is workable. I will re check tomorrow in the daylight. Yes I do have a 10 bolt, so you said you have these lines up front and they worked? Where did you get them, and did they have them in stock? What lines are you running?
  4. sandawgk5
    Oct 28, 2003
    6,881
    I got them at pepboys and they were in stock. I asked for brakes lines from a 93? C1500. Basically any 1/2 ton IFS chevy truck or SUV from 92-99. I have 4" of lift and I run the 25" long lines on my Dana 60. Dana 60s and 10 bolts use the same brakeline fittings on the calipers.
    Ira
  5. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    Thanks IRA your a life saver! Well I gotta sleep so I can get up early and fix the truck, thanks again. Will try to post pics tomorrow!
  6. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I can find a part number for a rear brake line that is like 26" long if you need one too I think it was 20 bucks
  7. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    I don't need a rear one, it works just fine. A little tight at full travel, but nothing to worry about.
  8. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    for what it's worth, shane74 has a good deal on extended brake lines and is an easy connection if you ever need wierd lines (like 1/2 ton at one end and 3/4 ton on the other or 10b on one end, d44 on the other.)
  9. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    SkyJacker Lines!
    I run SkyJacker brake lines. They are extended braided stainless steel lines, DOT aproved. I highly recomend them because I know they fit exactly and actually improve stopping power by eliminating the expantion in the lines that can happen with rubber hoses. Search http://www.summitracing.com to find the right ones for ya.
