Help..NO BRAKE LIGHTS
Discussion in 'The Garage' started by IDGMC, Feb 25, 2005.
  1. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    Ok, I posted the other day about my dash brake light staying on, Well today I was pokin around a realized I don't have rear brake lights when I push the pedal down. Also my cruise control won't disengage?! I really don't want a ticket or a wreck. Its a 91 1500 w/ abs (at the rear):confused:
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sounds like the switch on the pedal is bad or loose. check the wires also. IIRC its to the right of the pedal at the top
  3. IDGMC
    Feb 18, 2000
    150
    Idaho
    thanks I'll give that a try in the morning. Would a bad switch affect the cruise control also??
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the crusie shuts off when you step on the brake, i think they both use the same switch, so if the switch is bad then the cruise is not getting a signal to shut off.
    if they use a different switch, it might be the tab sticking out the touches them is bent or missing.
  5. IDGMC
    Feb 18, 2000
    150
    Idaho
    Thanks for your help! I've only had the blazer for a week, so i'm trying to work out all the bugs
