Help No Headlights
Discussion in 'The Garage' started by 1BadK-30, Feb 25, 2007.
  1. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    Ok here is the thing, one day I go out and start my truck up so cause it has to sit and the headlights work. Another day comes along and i have no headlights and no work was done to it. I have no idea where to start guys, or the know how. Would anyone care to point out the simple stuff to look for first then we can go from there?
    I know the headlights themselfs are not out because my Father has a few other things wired that work off the same thing. Id ask him for thelp but he wont tell me or listen to me...
    Any help is very appreciated.
    Thanks guys
  2. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    turn the lights on and wiggle the plug for them. mine were like that.corrosion BABY.that or maybe one of the grounds are bad.
  3. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    if that was the cause then why wouldn't the guage pod lights work?
    sorry if im cooming off like a jerk im just really confused and pist off
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Well, do they?
  5. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    no, nothing works thats wired into the headlights.
  6. Can Can
    15,552
    136
    I assume you've double checked all your fuses?
  7. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    placed all new ones straight from the box in.
  8. boggerless
    May 26, 2003
    22,728
    96
    you said there was other things that worked off the same wires. are they disconected now? if so look for an open connection or broke wire.
  9. Can Can
    15,552
    136
    Are you sure the problem doesn't lie in the swtich itself? Like Daryl said, if the switch is bitched, you'll lose not only your headlights but also your gauge lights and usually your dome light. Does your dome light come on if you rotate the headlight switch?
  10. boggerless
    May 26, 2003
    22,728
    96
    look at the grounds. from sitting, there might be a bad connection.i had alot of problems with this myself.
  11. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    Not sure if anything is disconected or wires broke, i tried to follow a few wires and from what i could tell they were fine.
    Canmore, the dome light doesn't come on eather. Im starting to think the switch itself is bad but im not sure how i would test it, using a multimeter?
  12. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    would you happen to know where the grounds are?
    sorry guys i really have no idea where this stuff is
  13. boggerless
    May 26, 2003
    22,728
    96
    what year is your truck bro???
  14. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
  15. boggerless
    May 26, 2003
    22,728
    96
    look for the ground wires. each headlight has its own ground on the core support.and there is a ground for the dash lights to the left of the dash.i'm trying to help. i chased ghosts in my wiring for awhile myself.:D
  16. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    thanks i really appreciate your help means alot. tomorrow im going to go back at it, to mad right now. is there away to test the light switch?
  17. boggerless
    May 26, 2003
    22,728
    96
    that i'm not sure of.don't get pissed,thats how i missed most of my problems.one loose wire is all it takes. tommorow will come and you'll get it fixed.:D
  18. NewUser
    NewUser 1/2 ton status
    Feb 13, 2007
    528
    Chattanooga TN
    sounds like the headlight switch is shot to me....or possibly the dimmer switch if its floor mounted :dunno:
  19. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    to turn them on is to the left of the collumn, im assuming thats the switch and the dimmer is connected to it.
  20. NewUser
    Feb 13, 2007
    528
    Chattanooga TN
    your dimmer switch is connected to your turn signal arm if im guessing correctly....the headlight switch is mounted to the left of the steering column in the dash right?.....sounds like the headlight switch is fubarred to me
