HELP NOW HELP NOW TCASE PROBLEM!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78K5395MT, Oct 10, 2002.
  1. 78K5395MT
    78K5395MT Registered Member
    Aug 31, 2002
    27
    Winston-Salem, NC
    my truck is stuck at the bottom of a hill near my house and won't budge. the transfer case is in neutral or high, but it won't shift at all!! I push it forward but it won't go! It simply will not move!!help please!! i know it's late, but my neighbors don't want it in their driveway i don't think!!
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    get under it and check the shifter linkages.
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    unbolt the shifter linkage and try to shift it by hand (while you under the truck). worst case pull your drive shafts and have a buddy pull you up the hill and then you can figure it out from there.
  4. 78K5395MT
    Aug 31, 2002
    27
    Winston-Salem, NC
    since i have a dropped transfer case the metal surround was blocking it from goin into high- as soon as i pulled up the metal around it and clicked it in high loc then the case moved freely. i got it up the hill- thank heavens!! what scared me the worst is that i had just gotten it back from an engine swap. . .i almost started crying i was so mad. /forums/images/graemlins/k5.gif
