help oil probs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by trailblazer1980, May 6, 2001.
  1. trailblazer1980
    trailblazer1980 Registered Member
    Apr 1, 2001
    8
    BC canada surrey
    okay i have i problem just rebuilt my carb did a tune up i went to drain the oil and i had about 10 liters of it was mixed oil and gas does any one have any ideas what could cause it and how i might fix this every one i've talked to said they've never heard of this happening before please help thanx
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I have had a crankcase fill up with gas on a carburated Jeep with a 360 engine. Mine was due to a fuel pump diaphram leak.
  3. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    I don't know if it'd give you 10 liters, but check your choke. Check the canister for fuel too. There was a post about this recently that went into some detail. You may want to do a search for it. Hope this helps....
    Why do people keep calling it a Bronco!!!!! [​IMG]
  4. trailblazer1980
    Apr 1, 2001
    8
    BC canada surrey
    i need to rewire my choke and i don't have a canaster i have replaced both my fuel pump and intake gasket any other thoughts before i decide to pull the engine and rebuild it. the oil filled up 2 5L oil pans
  5. dyeager535
    26,975
    Only way that I can see oil getting into the crankcase, besides fuel pump, is if it is somehow spewing into the air cleaner, and the breather from the air cleaner is allowing the motor to ingest it. Nothing on the carb has access to the crank case...only place fuel goes is the intake....guess a bad intake to head gasket could allow fuel to leak into the crankcase as well...
    Dorian
