Help on axel swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rezalb, Nov 4, 2000.
  1. rezalb
    rezalb 1/2 ton status
    Apr 6, 2000
    207
    Phoenix, AZ metro
    I have a 1983 K5, I also have a 1979 3/4 suburban parts truck. I would like to take the Suburban axels and Rancho suspension (as complete systems) and just move it to the Blazer. MMMMMMMM, I did a search on this site, but nuttin really got to the goodies.
    Thanks again guys,
    rezalB
    Built for a purpose.
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    i'm not totally sure but, the rears should bolt right up.. if anything you'll have to move the spring perches and shock mounts..also, if you are going to use the sub. leaf springs then measure your springs to make sure they are both the same length.. don't know if they are longer or not.
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Just unbolt the springs from the frame on the sub and roll them (with the axles) under your K5. Everything should bolt up. You will need a 1350/1310 hybrid u-joint for the rear driveshaft, Napa has this. Everything from the sub should bolt up to the K5.</font color=blue>
  4. rezalb
    Apr 6, 2000
    207
    Phoenix, AZ metro
    Sounds to Good to be true for me, I will let ya all know.
    Thanks,
    Again this site gives me inspiration and hope with my project.
    rezalB
