help on fuel tank
Discussion in 'The Garage' started by 91k5NC, Aug 21, 2002.
  1. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    alright, it started will a long starting problem and gage not being correct, so dropped the fuel tank comes out to being needing a hole fule tank assembely, so bought one out or a 88 k5 used, thought that may work, well put it in and the gas gage reads backwards and ( don't now if the fuel pump is supposed to run when i turn the igntion on or not) the fuel pump does not turn on. checked the fuses don't now if it is the realy or not. does the fuel asemblies match up or not ( i have a throttle body injection in mine) the 88 did have one in it, thought i would post it because yall have helped me out alot before /forums/images/icons/grin.gif . thanks.
  2. 91k5NC
    Jul 12, 2002
    206
    Durham Nc
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    buddy the 88 did have TBI on it. it ran, i promise ya. i'm not trying to bull$hit you out of some money. just go back and double check the wires where you spliced them in. or maybe that pump sitting there that long just doesn't work anymore.
  4. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    and if you aren't happy with it, bring it back and i'll give you half of the money back you gave me for the seats and fuel assembly. i know what TTT means = to the top, but what the he!! does to the top mean? I'm retarded so just slap me whenever you see fit.
  5. 91k5NC
    Jul 12, 2002
    206
    Durham Nc
    i don't think your bull$hiting me just wonder if any body nows about it, i put this up before i talked to yah.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would say check your wireing yes the fule pump should run for a few seconds when you turn the key on
  7. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    maybe the ground is not connected to the fuel pickup / gage assembly
