help on hookinh up tach on HEI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bwoodard, Dec 26, 2001.
  1. bwoodard
    bwoodard Registered Member
    Oct 29, 2001
    43
    Chicago, IL
    Can someone tell me where the green wire from the tach goes on a HEI distributer, Or just tell me where to hook up all the wires.
    Thanks Brian
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I assume your 'green wire' that you refer to is the 'tach' signal wire for the coil...........right? If so, there is a plug/connection on the HEI that says 'TACH' on the little ear that sticks out for this hookup.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  3. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    yes, on the side of the distributor cap, where the wires plug in from the distributor base and wiring harness, there is an empty terminal marked tach on the cap. hook the tach signal wire to that terminal
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: <a target="_blank" href=http://community.webshots.com/user/wdb172454>http://community.webshots.com/user/wdb172454</a>
  4. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    A .250 Female spade will plug onto this "Tach" connection. Just crimp one onto the end of your wire and press it on. A small mirror might be helpful on the first try.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  5. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    Soory to change the topic a little bit, but what all is involved in the install? I imagine the tach would have a power wire and a sender wire......Where do you hook the power up to?
    Where have you guys installed your tachs other than the dash?
    <font color=blue> NEVER FORGET, NEVER FORGIVE, NEVER SURRENDER<font color=blue>
  6. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Red is 12 V keyed hot
    White is power from the instrument lights so the tach will dim with the panel
    Black is ground
    Green is Tach signal from the distributor
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
