help on my 10bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by -Jaden-, Jul 20, 2000.
  1. -Jaden-
    -Jaden- Newbie
    Jul 20, 2000
    4
    recently bought an 84 k5 with a 10 bolt rearend, upon removing the rear brakes I found I need to replace the wheel bearing seals at the minimum, only problem is I cannot get the axles out, I cannot get the pin from the carrier to get the c-clips out,,,,,,,,,,,,,,,any help?
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    as long as you removed the bolt that holds the carrier pin in it should come out. You may try pulling out on each of the axel shafts to release any tension on the pin. If that dont work use a piece of pipe just smaller than the pin and place it at one end of the carrier where the end of the pin is located then beat it with a hammer till it comes free or you break the whole darn thing..then you have an excuse to get a 14FF
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    did the bolt pin break off? or is the cross pin damaged?
    your right. I don't understand the jeep thing!
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    A lot of times, the retaining bolt will break, and part of it stays in the hole. Look at the piece you took out closely, and see if the end is broken off.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  5. Blazer1970
    1,600
    Old Mission, MI
    He e-mailed me, saying that the retaining bolt was broken. I sent him this URL from Chevelles.com for anyone else that may be interested.
    http://www.chevelles.com/forum/Forum9/HTML/002831.html
    Tim
