Help on stabilizers!!
Discussion in 'The Garage' started by Frogg89, Aug 24, 2002.
  1. Frogg89
    Frogg89 Registered Member
    Jul 29, 2002
    85
    Southern NJ
    Hey guys, Im lifting my 89 6 inches and I have the stock stabilizer. I want to go duals, Can I just buy another single kit and put it parallel of the OEM or is it more complicated than that. The dual kits that go on top of one another are far more expensive than the single. Id appreciate the help!!!
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Why do you want the dual kit? Get the lift done and see if you actually need it, no reason to run it if you don't need it. I ran 38s on 6" lift and never needed more than the single. Even ran without one at all for awhile and it worked fine. </font color>
  3. Rasberry
    Rasberry 1/2 ton status
    Mar 30, 2001
    205
    Orlando, Fl
    I'm running 6" with 35's and I just bought a single Pro comp stabilizer to replace my OEM. I used the existing mounting brachets. Its worked just fine so far.
