Help, overheating problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77k5, Oct 28, 2000.
  1. 77k5
    77k5 Registered Member
    Oct 16, 2000
    9
    I have a 350 that is getting hot going up hills, and cools down going down hills, I've replaced all the normal stuff (new radiator, water pump, heater core, and a new therm.) and I have backed off on the timming. I've been told that a trany could cause the engine to run hot, the transmission lines were hot, I couldn't hold them for a second, Is this normal?
  2. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    What kinda fan do you have? Clutch or direct?
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red>, it's a population control thing.</font color=blue>
  3. 77k5
    Oct 16, 2000
    9
    I've had a flex fan with shroud, and a stock clutch fan on it with shroud, and now I have a 16 in. electric fan. It has done the same thing with all three fans.
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I'm assuming auto trans...
    With everything you've done so far, I'd say it's time for a real transmission cooler. Get a good-sized one (20,000 lb. GVW) and your trouble should be over.
    [​IMG] Semper Maintenance!
  5. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    I would definately recommend a tranny cooler. Also what temp. thermostat is in it?? Was it replaced?? try a 195. Also try prestones cooling system flush even though you've replaced a lot of cooling system items. Sometimes you get build-up in the block as well, this will clean it real well.......js
  6. 77k5
    Oct 16, 2000
    9
    I have a 160 therm. in it right now, I've had a 180 in it and a 195 and it really got hot. The engine now has about 2,000 miles on it. I have a trany cooler but I mounted it a little bit down, I thought it would help the air flow through the radiator, but that didn't work, What is being used as a tranny cooler really looks like the coils off of an old ac unit.
  7. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    This may be kinda obvious but do you still have the fan shroud?
  8. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    My das 454 vette was doing this, turns out the radiator was restricted towards the bottom. Radiator was rodded out and no more problems. Hope this helps.
  9. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Sorry did'nt see you repalced the radiator. Could it be a rstiction in the block?
  10. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Sorry did'nt see you repalced the radiator. Could it be a restriction in the block?
  11. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    i was having the sameprob this past summer, but i have not seen it since i have staying out of OD in the hilly areas. Some things that i notices was it would not only get hot when i was going up a hill but if i had a strong head wind. I think that mine was mostly the trany slipping due to the extra power needed to push a barn down the highway. I am plainning to change my rear-end, when i get the money from 3.42 to 4.10 or 4.56, and i am hopping that that will help to. Let me know what you good info you get.
    brettmcox.coloradok5.com
