Help! p/s pump pulley slipping
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer79, Jul 29, 2002.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    When I swapped my 454, I had to remove the pulley from the power steering pump because I had to fabricate some brackets to bolt it to the 454. Since then, when turning and standing still I got this whinning from the p/s pump. I thought it was going bad, but after carefully listening, it actually sounds like the pulley is slipping on the pump shaft.
    I was going to spot weld it, but a friend told me that it would become unbalanced and that would destroy the pump quickly. How should I fix this?
    Any help appreciated.
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    pull it and inspect it for evidence of slipping.
  3. Blazer79
    1,816
    I marked the position of the pulley to the shaft, started it and steered a few times. The marks are off now, so there is evidence that it is slipping. Now how should I fix it?
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    IIRC that is a press fit pulley.
    you may have pooched the shaft
  5. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    please explain "pooched" ?
