help please: anyway to check electric choke to see if it works ?
Discussion in 'The Garage' started by big d, Feb 21, 2004.
  1. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    i have two disassembled electric choke mechanisms here and i may be converting my thermo choke to electric, any way to check to see if the electric's work ? /forums/images/graemlins/ears.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif thanks in advance. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Hook them up to 12v and see if the spring moves.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    it may not move immediately but like he said. I did this for a while. last year I was running the electric choke manually on my K5, unplugging it when I wanted to shut it off.
  4. dyeager535
    26,979
    Check to make sure the electric chokes will fit. *SOME* Q-jets won't accept the electric choke, they are cast differently in that area.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I was wondering since we are on electric chokes, does the later 70's with the heat choke and hose bib on casting accept the electric choke? I have a friend (heep owner ) with 2 barrel soon to be q-jet off old car and wants my old electric choke from my original carb ( couldn't bear to pitch it just needs bushed)? I assume youjust slip in electric unit and tighten down the 3 screws.
  6. dyeager535
    26,979
    IIRC you have to replace all the choke pieces underneath the choke coil as well. I really can't recall why exactly with wouldn't fit. I *think* maybe it was the way the coil mounted to the carb itself.
    Quite a few people have done the swap on here, apparently, I'm the only one thats run into this, so it may be that only one or two vaariants won't fit right.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thanks /forums/images/graemlins/thumb.gif
