HELP PLEASE! humming noise from rear end
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Nov 14, 2003.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    Weird humming noise. PLEASE HELP.
    #900762 - 11/13/03 04:42 PM Edit Reply Quote
    I just swapped my 10 bolt with a 3.73 12 bolt. It makes a somewhat loud humming noise that increases with speed. I had the brakes done so it is not the shoes/drums. could this be wheel bearings? If not, what else could be causing this noise. Fluid level is fine in the diff. the ring and pinion dont seem to have any bad wear. all edges on the gears are sharp and clean. Any help would be great. I am a bit worried.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah, that sounds to me like a bearing issue
  3. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Ditto what Muddy said /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    is it a deep hum? or higher pitched? it could be either the bearings in the end of the axle (wheel bearings), or the carrier side bearings..
