HELP PLEASE T case ?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyfumes, Jul 15, 2002.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I was trying to tell if my rear end was fawked or if my transfer case is fawked, so I took out the rear drive shaft and I was able to turn both yokes (axle and t case) about an inch, is that bad?
    Then I wanted to see if I have a part time kit or not, the previous owner installed hubs but it looked like the front drive line was turning when driving . so after removing the rear drive line I put it in reverse and nothing happened so I locked in the hubs and it went into gear and I backed it outta the drive way turned around and started up the road. About30 ft. later there was a big CLUNK and the front stopped turning so I had to coast backward into the garage... WTFThen after letting it sit it works again but is doing some wierd ass sh!t.... /forums/images/icons/confused.gif /forums/images/icons/confused.gif /forums/images/icons/confused.gif
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Can you get it to my house? If so, we can take it to a guy up the street who can tell you EXACTLY what's up with it.
  3. chevyfumes
    Feb 24, 2000
    38,584
    266
    Yeah I can put the rear drive shaft back in when can I come over?
  4. chevyfumes
    Feb 24, 2000
    38,584
    266
    anyone else have any ideas?????? /forums/images/icons/confused.gif /forums/images/icons/confused.gif /forums/images/icons/confused.gif
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Normal gear lash from what I've seen.
    If it was converted to part time, with it in 2HI you should be able to turn the front driveshaft by hand easily.
    Did you shift the transfer case? Or was it in it's usual 2HI position? Was the big clunk during a turn? Might be the front wheels binding with only the front shaft driving them.
    Or then again, maybe you found my recipe for Snakebite irresistible. /forums/images/icons/laugh.gif
  6. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    I am going to see Jamie tomorrow night w/ Jason Brown to drop off his axle. Jamie's about 4 blocks from my house. How about tomorrow night at 5:30? I tell ya, Jamie's DA MAN when it comes to this type of stuff!! /forums/images/icons/grin.gif
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    I just tried all positions on the shifter and it wstill drove the front and I think it needs a new chain anyhow so I'm gonna order the part time kit too, I'll wait and see if that fixes it if not then I'll be needing DA MAN to look at it...LOL thanks guy's.
    Also I just pulled the dif cover and eveything looks good except for normal wear, and as for the vibration I was having I figured that out too, I didn't have the ujoints lined up on my front shaft.... /forums/images/icons/crazy.gif
  8. chevyfumes
    Feb 24, 2000
    38,584
    266
    I found a chain at Summit for 83.00 does anyone know where to get one cheaper....... /forums/images/icons/crazy.gif
