help please
Discussion in 'The Garage' started by cole01, May 26, 2005.
  1. cole01
    cole01 Newbie
    May 25, 2005
    4
    lousiana
    I have an 80 k-10 and I am planing a build up but need guidence. I want to start with a lift but I dont know how big I should go 6" or 8" which company has the best lift? I want to run 39.5 boggers. Is this too much tire for stock drive train? :confused: The truck is not going to be show quality by any means. I will cut the fenders, and would like to have 39.5's but if I have to for reliability I would go with a 37 or 38.5. Is a regular swamper a better choice than a bogger? Rough country has a 6" that is resonably priced. Is this a good product?
  2. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    you'll need beefier axles at the least with you lift, 10 bolts aren't known for holding up to much beyond stock tires, other guys here can point you in the direction of what you need to do for everything else like your tcase probably need shims, axles need to be shimmed to reduce driveline angle, probably need new driveshafts with that much lift, better brakes, crossover steering probably as well
  3. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    I run 39.5s with 5" of lift and cut fenders and I sometimes rub at full stuff. as for drive train , that depends on what you do with the truck. Lockers increase the chance of breaking stuff, so does your right foot. I have a dana44 front thats open with the 39.5s on and have never broken it. the way I see it ,I can spend $1200+ on a front dana60, or with dana44 shafts at about $100 I can break and fix 12 times...
  4. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    the question to ask yourself is "why do I want x" of lift?". Is it for the look? is it to fit bigger tires? In general terms, the more you lift, the more it will cost and the more complications (steering, driveshafts, brake lines etc etc) come up. If you just want to fit big tires and don't really care about lifting super high, trim the fenders. If you're going for show truck bling, then be prepared to mod a lot of stuff.
    yes, boggers are relatively heavy for their height. I wouldn't run them on 1/2 ton stuff unless street-only / show truck are the goals.
    j
  5. cole01
    cole01 Newbie
    May 25, 2005
    4
    lousiana
    Thanks for the guidance
    I am definetly not building a show truck by any means. I do want to fit bigger tires, I will cut the fenders without hesitation. I would still like to run the big 39.5 boggers but would be willing to step down to a 37 if I had to. So it sounds like I am going to go with a 6" lift and some finder trim. The truck will be just a trail ride and hunting truck so I am not worried about looks. Thanks again for all the response. I hope to get some pics as soon as posible.
