HELP PLEASE???????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lance86blazer, May 23, 2001.
  1. lance86blazer
    lance86blazer Registered Member
    Oct 17, 2000
    11
    UTAH
    I have a 1986 k5 blazer that is makeing a clanking noise when i am driving and when i let off the gas a little bit to stay at a steady speed it is the worst but when i let off the gas all the way the noise goes away intell i am almost to a complete stop the noise comes back for about 5sec and stops i have tryed every thing i can think of and i cant figure out what it is does anyone know
    UTAH BLAZER
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    SOunds like loose metal parts vibrating maybe?
    My president is Steve Fox.
    90-350TBI-TCI700-241-33"-10 bolts w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  3. lance86blazer
    Oct 17, 2000
    11
    UTAH
    yeah thats what i thought it was but i have looked and i cant find anything loose
    UTAH BLAZER
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    My first guess is going to be that you may have some exhaust pieces loose somewhere or some bad u-joints.
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Try license plate bracket, spar tire bracket, bumper and hitch bolts.
    Have you tried replicating with engine RPM in park? Easier to have someone listen.
    Don't do the Darwin Award thing and crawl under your truck while someone is driving. :)
    I think the exhaust suggestion was the best bet so far.
    Dave
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Yep. Get underneath there with a flashlight if needed, you'll find some metal wear spot somewhere. Just a guess though...........HTH
    <A target="_blank" HREF=http://fwp4x4.coloradok5.com>http://fwp4x4.coloradok5.com</A>
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I'd kinda lean towards the u-joints also......Dan
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,088
    488
    Grand Rapids area
    This sounds just like blown U-joints to me. Check out both of them on the rear driveshaft, especially the rear one.
    <font color=green>"I don't have the brains for business. I want to go into politics" -Mao Xinyu </font color=green>
  9. MrsDB
    MrsDB Registered Member
    May 23, 2001
    16
    Dallas Texas
    It depends where the noise is coming from. Have you tried having someone else drive the k5 down the block... and u listen... that would give a better idea of where to look... other then that... Are you getting a strange vibration in the floor board at all?
  10. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Do you still have that stupid catalytic converter shield underneath the driver's seat? That thing makes a hell of a noise when it gets loose.
    I have voluntarily axed "Pancho" in a bandwidth conservation effort [​IMG]
  11. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It sure sounds like it's one of your driveshaft u-joints- get under the truck and pull and push on your rear driveshaft. If you get any noticeable movement it's sure to be a bad u-joint. Have you noticed any clicking(like rocks stuck in the tires) while you've been driving lately? That's what you'll hear when a u-joint start to let go. It will eventually graduate to the clanking sound, and then one day will just fall apart...........
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    Are your hubs locked in? It could be a bad u-joint or CV jont in your front shaft.
    <font color=green>MIKE</font color=green>
    <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
