Help please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by luvmyk5, Jul 8, 2002.
  1. luvmyk5
    luvmyk5 Newbie
    Jul 8, 2002
    4
    Washington
    I need some help guys I have bought a 1984 K5 blazer and its been one big headache after another ( was not taken care of ) So far I have replaced the distributor, starter, alternator, plugs, wires, and carb. Thought I had all of the bugs worked out until the other night was waitng for some friends at the drive in and I was ideling and it just died and would not restart its getting fuel but im not getting any spark (new distributor) the fuesable links look good I'm stumped, any other suggestions would be greatly appreciated.
    Scott
  2. random
    random Registered Member
    Jun 12, 2002
    13
    maine
    Right off the top of my head,check for 12 volts at coil in cap,make sure your tach wire hasnt grounded out.Then maybe relace module and coil one at a time.Sounds like u mightve got bad module..it happens.good luck!
  3. luvmyk5
    luvmyk5 Newbie
    Jul 8, 2002
    4
    Washington
    thanks ill give it a try
  4. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Definately check for 12 volts at input wire to distibutor! I had the same problem with a buddies 86!
  5. luvmyk5
    luvmyk5 Newbie
    Jul 8, 2002
    4
    Washington
    thanx ill check it out
  6. Grim-Reaper
    7,385
    Atlanta
    Is that the ESC distributor with the computer box up behind the glovebox? If so, and you need it, I have every thing but the coil and knock sensor for sale. That includes the brain, distributor housing and the wires. Looking for $75 for the whole thing. Was working fine when I pulled it off a 85 Doaner truck and the distributor housing looks near new. The truck was a very well kept up total it came off of had about 10k on a Crate engine (why I got it in the first place).
  7. luvmyk5
    luvmyk5 Newbie
    Jul 8, 2002
    4
    Washington
    No its npt the ESC distributor but thanks for the info and thanks everyone else for the ideas but I finally figured out my problem Im sending voltage spikes through my module and its frying it so I need to find out where my short is so thanks everyone
