Help....please
Discussion in '1983-2005 S-Series models' started by Halffast, Jun 25, 2003.
  1. Halffast
    Halffast Newbie
    May 22, 2003
    3
    I am desperately seeking information about lifting an S10,crewcab up. Looks like you guys know more about this than any group I've seen. Any ideas how to go about doing this. I, know that someone said that you can pull up the front end with the torsion bars,but I would like to go another route than that.Would balljoint extensions work?? Just grasping for straws there, but it doesn't have springs on the front, only shocks...
    Any help...any...would be appreciated greatly.
  2. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    no such thing as ball joint extenders.
    you can crank your torsion bars.
    put on a 2" suspension lift which involves
    the same process and longer upper a arms.
    or you and do a 5" suspension lift which is alot
    of work.
    or do a 3" body lift
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    There are Ball joint spacers, but those are to correct Camber in coil lifted 2wd trucks. You're only hope is a body lift or a real lift kit if you don't want to crank the bars.
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    the price of a 5" IFS lift is about the same as a solid axle swap... do it once.. do it right... solid axle that beotch
  5. GQ 350
    GQ 350 Registered Member
    Jul 20, 2002
    19
    Kelowna, British Columbia Canada
    /forums/images/graemlins/rotfl.gifThe cranking up the torsion bar is not so bad, as long as you don't go too far and you get the front end checked out and set up again after you do it. If you do that and add a 3" body lift it will give about 5"s of lift give or take, with that you will be able to fit 31"x10.5"s all on the stock rims and clear them well to. If you want bigger tires than 31"s you will need to get some kind of suspension lift,such as a 2",4", or a 5"and 6" but they all are a fair bit of cash. Adding cut out flars is a bit cheeper but it is hacking the sheet metal, and myself I hate to cut into the body like that.
    well I hope I have given you some options to think about /forums/images/graemlins/pimp1.gif /forums/images/graemlins/truck.gif
