Help!! Possible Carb. Problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Feb 5, 2004.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    When I start my blazer up in the morning it starts and idles fine. After it runs for 10 minutes or so and i go to drive the idle kicks down and everything. However, if i hit the gas to pull out of my neighborhood, the truck will stall, or come damn close. What could be causing this? Could it be a vacuum. After the first couple of minutes of driving there are no more problems.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well its pretty cold there in the mornings huh? A lot of GM cars and trucks do that in winter. May just be choke related, cleaning and adjustment time. I got mine to where I think it will never do it again , and we have a cold night and once in awhile it does it again. I have found letting it warm up a couple extra minutes helps /forums/images/graemlins/k5.gif
  3. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    Choke problem, not vacuum. Vacuum problem would be a problem right from the get go.
  4. zach78k5
    May 14, 2000
    406
    It even did it during the summer. should i just change the choke all together?
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    what kind of carb? stock qjet?
