HELP!!!posted numbers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CBLAZER81, Aug 4, 2001.
  1. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    Does anybody know where I can find the codes for gear ratios?
    The father in law blew out the rear end in his burb and all he could give me was the numbers off the axle housing and from the ring gear.I need to try to find a replacement with the same gearing but I need to figure out what it is first.
    Well,turns out he gave me the wrong #s.he also figured out that he has 3:73 gears in it.really appreciate all the help!Now just have to find a replacement.
    Chuck
    81 Blazer
    <font color=red>WHY CAN'T EVERYBODY DRIVE LIKE ME?THE WORLD WOULD BE A MUCH BETTER PLACE!!!!!!!!!!</font color=red>
    &lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by CBLAZER81 on 08/04/01 12:21 PM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;<P ID="edit"><FONT class="small">Edited by CBLAZER81 on 08/04/01 05:44 PM.</FONT></P>
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Re: HELP!!!need help finding gear ratio
    well what are the numbers off the ring gear. Those numbers will tell you what the ratio is. Post it for us....
    Crawlin the rocks with my K5
    <a target="_blank" href=http://www.rockreadyk5.com>http://www.rockreadyk5.com</a>
  3. CBLAZER81
    Mar 3, 2000
    281
    Milliken,COLORADO
    #s on ring gear-3817778 11:44GM 05951
    That is what he gave me.Would it be 4.11s?
    Also,will the rear from a blazer or pick up fit in a burb?
    Chuck
    81 Blazer
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
  5. CBLAZER81
    Mar 3, 2000
    281
    Milliken,COLORADO
    Thanks but all I have is the numbers.Father in law lives about 2.5 hrs away and trying to go with what he told me over the phone
    Chuck
    81 Blazer
  6. 82GMC
    82GMC 1/2 ton status
    May 14, 2000
    553
    Seattle Washington
    <blockquote><font class="small">In reply to:</font><hr>
    11:44GM
    <hr></blockquote>
    Unless I'm wrong, those numbers whould be the tooth count, So you divide 44 by 11 and you get 4, So that whould mean you have 4:10's[​IMG]
    [​IMG]Inline 6's are cool[​IMG]
  7. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Yes the rear from a blazer or truck will fit a burb. Just make sure your spring perchs are in the same place and if you get one from hub to hub make sure the wheels match the studs.
    I do know that rears from 1/2 ton vans are 3 inches wider than the others and you have to move their spring perches.
    Hope this helps.
  8. CBLAZER81
    Mar 3, 2000
    281
    Milliken,COLORADO
    Thanks everybody! Greatly appreciated!
    Chuck
    81 Blazer
