Help Power rear window rolls down but not up
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, May 27, 2005.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    My window will roll down but not up. I bought a new motor and that is not the problem. It used to work fine and then stopped one day. could it be the switch? Anyone run in to this before. Are there seperate fuses for up and down? :confused:
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    you try both the switch on the dash and the key switch in back?
  3. zach78k5
    May 14, 2000
    406
    the key switch does not work because I never recieved the key. The front switch used to work fine and one day the window just wouldn't roll up with the switch.
  4. dave_90_blazer
    Jan 1, 2004
    688
    probably the switch, the motor uses the same wires and fuse for up and down
  5. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    sounds like the cable to me, mine did this a few months back, would roll down but not up.
  6. zach78k5
    May 14, 2000
    406
    I have unplugged the cable and only attatched the motor and it only spins when i push the switch to the down position.
  7. nc87k5
    Sep 23, 2003
    5,231
    North Carolina
    hmm, got me there. may be like one of the other replies. I do know how you can raise it up if you need to for the time being, get a drill and close the chuck onto the end that connects to the motor, then slowly raise it up.
  8. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    umm take off the switch and remove the electrical connector to the back of it and take a small gage wire and connect one end to the power and the other to the up wire and see if it works is so then the switch is not making contact between the power and up position wire try cleaning it up and see if you can fix it if not I believe lmc sells them for like $7
  9. chevy_addict
    chevy_addict 1/2 ton status
    May 4, 2004
    138
    You are here, I am not
    There is a silly safety switch (at least on my sub) in the tailgate latch on the passenger side that will only allow the window to roll up if that switch is depressed. You can try bypassing that switch and see if the window will roll up.
    Dave
  10. dremu
    Feb 27, 2000
    15,969
    462
    East of San Francisco
    Chevy Addict's right on. There's a safety switch (IIRC, on the right side latch) that keeps the window from being rolled out when the tailgate is down.
    I think it's stupid and I'd bypass the damn thing, as they fail all the time, resulting in exactly the symptom you describe.
    Should be a pair of light blue wires; remove the access panel inside the t-gate, find the wires, pull them off the switch, put a jumper across... or, if your tailgate is like mine ... just flip the latches back and forth a coupla times or WD-40 them, and the damn thing will start working again =))
    -- A
  11. toocalm
    toocalm Registered Member
    Feb 1, 2004
    13
    Long Island, NY
    Mine went down but not up, it was the cable...could take off the access panel, disconnect the cable from the motor and attach the end to a drill's chuck and raise it again with no problem. The cable was pretty cheap from Chevy too...
  12. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Correct.
    THe switch on the drivers side latch tells the motor not to move when the tailgate is down.
    It can roll down but not up
    This is just a saftey measure to keep the windo from rolling down while the tailgate is down
    just connect both ends of the switch and it will work again.
  13. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It also simply be that the safety switch is gummy and clciking back into place when the tailgate is closed. That happened to me once before. A shot of WD40 fixed it up.
    Try spraying down the right side latch of your tailgate and after closing it, give it an extra shove on the right side........
