HELP! problem with stalling/loss of power
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88GLAZER, Apr 23, 2003.
  1. 88GLAZER
    88GLAZER 1/2 ton status
    Nov 19, 2002
    111
    West Virginia
    I just recently installed headers on my truck and new exaust, After instalation I tested it out, and the truck ran like [censored], back firing and stalling. I found that I had cracked the porclin on one of the spark plugs. so I replaced it. Now the truck idles great, but has no power, significantly less than when I started. I dont think that the engine is getting enough fuel. I had taken my truck to school, and I could barly hit 70mph on a slight incline. and after 200 miles the truck started stalling. filally I left the damn thing in Hagerstown, MD and hoped in my girlfriends jeep. What the hell could it be! (Electrical,blocked fuel line)
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I an assuming this is about a 88 Blazer.
    Did you get the right headers? You need headers made for your truck with a bung for the O2 sensor. Did you install the 02 sensor? Your fuel injected truck wont run right with out it.
    Are the spark plug wires on the right plugs? check your fireing order.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    if you went 200 miles w/o problems, something happened...maybe you burnt a plug wire or two?
