Help! Problems with Holley TBI!!
Discussion in 'The Garage' started by mtrdrms, May 17, 2005.
  1. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    My truck runs like SH$T!! I set the idle, there are no vacuum leaks, its getting fuel, what else could it be. It ran fine before the direct replacement swap. The only thing Idid not do is unplug the "idle air control unit". what is an idle air control unit? where is it located. the instructions say to disconnect it before setting idle. I didnt do this. also it says to adjust the TPS to .65 volts. What does that mean? Jeez I thought I knew something about trucks before I got this. I know the computer has an adaptive memory and supposedly should get better but does anyone have any suggestions?
    It rips above like 3000rpm but before that it falls on its face. could that be from lack of fuel pressure? i never replaced my fuel pump. Also FYI, it is a 350FI, 87, mild cam upgrade, balanced, aluminum intake, thorley headers, to flowmasters - no cats. could there be not enough backpressure? I know its alot of questions but I am frustrated. Thanks. Andy
  2. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    well my idle air control went out on my t-bird and it would not run at all or would not idle high enough and would just shut off, what was my problem. i need a new tbi so i dont know much about replacing one on the k5's
  3. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    I can't help you, except to say you're not alone. I've read tons of posts about the Holley TBI "direct replacements" and all the problems they've given guys on this forum who are experienced wrenchers. Maybe if no one posts up an answer for you, you could sift through the old posts, I remember at least one guy finally got it working good in the end. Good Luck.
  4. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    Thanks man. I appreciate the support and I'll do a search and try to find out what I need to do get this thing running right. - Andy
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    You need to put the jump wire between A&B on the aldl socket. Turn ign on but don't start it. Wait 30 secs then unplug the IAC plug. It's the square plug on the right hand side of the throttle body (as you sit in truck). It sticks out and backwards a bit, not the vertical one just in front of it (TPS). Take jumper wire out, start engine and set the idle speed. Switch off, replace plug and disconnect battery for 1 min. Run and check idle!
  6. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    Awesome. But what is an aldl socket?
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Look under your dash, mines just left of the steering column, for a black wiring block. There's 10 or 12 holes in it. It's about 3/4" by 2" The top 2 right hand holes are the earth and diagnostic terminals (A&B). That's where you put a jump wire between them. If you have a manual look in there under emissions and diagnostis.
  8. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    paperclip works great
