HELP! Problems with muffler bearing
Discussion in 'The Garage' started by BigBurban350, Apr 19, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Whats a muffler bearing.../forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Did ya use plenty of squelch grease when you replaced it?
  3. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    please refer to the non4x4 forum for answer, its in the
    " MOST ANNOYING POST TITLES " THREAD. /forums/images/graemlins/rotfl.gif
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Muffler bearings are VITAL on vehicles today! They provide so much dampening and support for the kinnooter valve assemblies, and we all know how important those are these days...
    Be sure to maintain your pneumatic fluid level, too. You wouldn't think muffler bearings and pneumatic fluid interacted with each other, but it's been conclusively proven that a problem with one causes a problem with the other...
    Stay safe out there!
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rotfl.gif
  6. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    Ken, you forgot to warn him about the blinker fluid level...semper maintenance!
    Rene
  7. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    /forums/images/graemlins/rotfl.gif i had a customer pissed yesterday cuz i said i wouldnt sell him a head gasket for his RX-7 (rotary) he was mad /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    Even more important than muffler bearings is keeping the proper tension on your carbeurator belt. /forums/images/graemlins/rotfl.gif
  9. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Don't forget to buy some relative bearing grease when you get your muffler bearings.
  10. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    And always remember to torque down your radiater cap and vacuume lines, and while your at it your dip stick, if you can reach it with your torque wrench, remember to use locktite as well, you dont want that sucker backing off down the road do ya /forums/images/graemlins/thumb.gif
  11. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Don't forget to check the headlight fluid, Change your frequency grease, and keep plenty of lanyard wax around so it doesn't rust....
  12. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    [/ QUOTE ] Blinker fluid and headlight water level stupid people drain th headlights when they see water in there but really theres water all the time its just so full the water keeps them from burning out /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Muffler bearings are used mostly in those little imports we refer to as ricers. They are used to alowe the coffee-can size fart-mufflers with neon lights to rotate.
  14. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Water in the light housing is essential to keeping the bulb assembly cool.
  15. BigBurban350
    Jun 9, 2002
    711
    Michigan
    My mekanic says I need timing rod seat valve, does anybody know how to replace those?????
  16. Ryan B.
    Jul 18, 2001
    5,693
    CA
    FYI-
    If you are going to replace your muffler bearing, you MUST replace your piston return springs at the same time...
    I hear they are a matched set. You replace one- you're replacing both.
    I would reccomend going with a higher spring rate for all the piston return springs just to be safe when you replace them, to ensure all the pistons will return to BDC while the engine is running. /forums/images/graemlins/thumb.gif
    If you're lucky you might be able to find a whole set of muffler bearings and piston return springs at the junkyard. Honda's and chevys are interchangable too, so if you can't find it on a chevy, any year honda should do.
  17. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,601
    551
    Wasilla AK,
    If your havin' probs with your muffler bearings you should also check the tension of your piston return springs /forums/images/graemlins/eek.gif /forums/images/graemlins/truck.gif
  18. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    I was just arguing with a buddy about the muffler bearings in my truck when our site foreman sent me to look for the skyhook. By the time I got back I was confused because they were all talking about turkey hunting and all I hunt is snipes!
