HELP. Problems with Tranny or Transfer Case!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rebel222, Oct 21, 2000.
  1. rebel222
    rebel222 Registered Member
    Aug 21, 2000
    58
    Louisiana
    I just yesterday bought a 1980 K5. It came with a problem. It doesn't go. Something is wrong with either the transfer case or transmission. When you put it in drive and press the gas it makes a whinning noise. I tried locking the hubs and putting it in 4wd to see if only the back axle wasn't spinning, but it did the same thing. I would greatly appreciate the help. Also, if someone knows, will I have to replace the part with the problem or just rebuild it? Thanks
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Put your t-case in lo gear and put the tranny in gear. Sounds like you have a bad tranny though.
    creepin' and crawlin'
    Jim
  3. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    Well the 1980 K5's came with the NP 205 exclusively, and I have a hard time believing that it would be the cause for your no go.
    Lets start with the simple stuff. Did you check the tranny for fluid? Is it really low? Is it really brown?
    Does the transfer case shifter move back and forth into all its positions?
    Are you in 'Park' or 'neutral' when you are shifting the transfer case?
    It sounds like you had the transfer case in neutral and tried to re-engage it in gear.
    Just some thoughts.
    Rene
  4. rebel222
    Aug 21, 2000
    58
    Louisiana
    The transmission was in park when I into 4Hi. It does shift into all 4 gears. It won't be here tomorrow, so I can't check the fluids. The guy I bought it from told me he was driving, and it all of a sudden went out. Who knows? Thanks
  5. rebel222
    Aug 21, 2000
    58
    Louisiana
    Also, if it is ruled that the transmission is bad, can any th350 be put in place of the one on there. I heard they came with 3 different types of bellhousings and 4x4 models had an intermediate bellhousing. Are they interchangeable?
