Help Quick Please... Trying to get rear axles out before dark!!
Discussion in 'The Garage' started by 78Blazer, Jun 12, 2003.
  1. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    I am tearing the gears out of my rear 12 bolt. I know the axles are held in with c clips... But where exactly are these clips at that I need to pull off? Do they just slide off????????
    TIA
  2. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    From way back on 8/13/2001 no less - Nice! That description and picture read like a book!
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Take the bolt out of the "cross shaft", pull it out a little way, shove each axle shaft in a little, and the "C" clip will fall out, then pull the axle's. /forums/images/graemlins/eek.gif
  5. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    If the c-clips are sticky sometimes a magnet helps get them out.
  6. 78Blazer
    873
    Michigan
    Thanks Guys and Gals.......... That pic made the explaining real simple....
