HELP QUICK! - Valve cover Question -
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Nov 30, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I am going to drop the motor in and have a set of Aluminum Tall SBC valve covers.. but one doesnt have ANY holes and the other only has an oil filler hole...
    Do I need a breither hole in the one side? Or can I leave it completely covered?
    One valve cover is no holes and one only has an oil cap...?
    They have M/T on the top of them and say chevrolet on them also in little letters on the sides...
    ??? /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/ears.gif
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    The valve covers on my BB only have 1 hole for the breather and 1 for the PCV valve. I just use the breather hole to pour the oil in...Pop the breather out and pour the oil in. /forums/images/graemlins/smile.gif Do your valve covers have a hole for the PCV valve too?
  3. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Aaron where are your 400 valve covers? Oh I bet they are getting cleaned along with my intake I am getting from you. Those will work fine, just cannot run a PCV valve. Sounds like your having fun See ya tomrrow Later Jeff
  4. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    No biggie dude, just but a breather in place of the oil cap. 283's didn't have ANY holes.
  5. reddog64
    Nov 9, 2000
    3,325
    Well my pcv valve has to go in the one side...
    so that means I have no breather and no oil filler.. I went and looked again.... /forums/images/graemlins/angryfire.gif
    Will that work? Or will it create some kind of vaccume that will have bad side affects... /forums/images/graemlins/shocked.gif
    HI Jeff!
  6. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Those are some OLD SCHOOL mickey thompson valve covers. Mickey Thompson actually stopped making valve covers last year, but any of them are worth some money to the right person.
    Personally I'd just run the PCV off of the one hole and fill from that side. Your crank case pressure might be a little off but it shouldn't hurt anything.
  7. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    I might just not use a pcv if I was in your shoes. Are you dead set on using those valve covers?
    On another note, if you are going to be pulling them on and off to adjust valves etc., smear some chapstick on the cover and the head. This way the gasket will be reuseable!
  8. eds77k5
    eds77k5 1/2 ton status
    Oct 19, 2001
    383
    washington state
    when i got my valve covers there werent any holes but there were supposed to be knock outs for the oil filler and pcv, well, they didnt knock out and i had to drill them out, one for the oil filler and one for the pcv, i put a oil filler cap that had a filter on it, cost about 12 bucks i think and drilled one hole for the pcv, i used vaseline to hold the gasket on, the new valve covers stopped a lot of the oil leak problems i had, good luck /forums/images/graemlins/smile.gif
  9. reddog64
    Nov 9, 2000
    3,325
    Look like these only no breather... /forums/images/graemlins/confused.gif
  10. eds77k5
    Oct 19, 2001
    383
    washington state
    similar to mine, where the oil filler is i put a cap that has a filter or breather i guess ya call it, it sits up off the valve cover about 2 inches i guess, just have to clean it once in awhile
