help quick
Discussion in 'The Garage' started by 99firehawk, Jan 19, 2004.
  1. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    What tools do I need to take out a guage cluster, turns out my speedo head only works in reverse, So I need to go pull one at the yard and need to know what tools I need. Thanks.
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    A Phillips screwdriver to take dash bezel off and small sockets, can't remember what size, and thats about it. You may have to pull the cluster foward and might have to feed the speedo cable from the firewall side to have enough room to pull cluster out enough to diconnect wires and cable. With mine, you have to lift left side up a little then pull left side out, slide over to the left and then It should come out. but no special tools are needed.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    philips head screw driver
    6 or 7mm socket
    i think thats it you should be able to take almost all of it apart
  4. 99firehawk
    Dec 15, 2002
    491
    cool, Thanks on my way to the yard.........
